Exhaust for Gti
kz
Exhaust for Gti
Post by kz »
Hello
Whether someone changed full exhaust in Polo Gti 6N2. I'm interesting to change all exhaust on stainless steel. I have a few question to YOU :
1. Whether you threw out catalysts?
2. On what you changed the diameters of pipes (you enlarged?) ?
3. Whether you put in sport catalyst?
Thanks for help.
Speedlaw
Moderator
Post by Speedlaw »
Hey KZ,
Welcome!
Yet another continental member, excellent.
I'm sure the GTI lads will chime in to actually answer your questions.
:oops:
KarlM
Post by KarlM »
hello KZ. welcome aboard.
to keep it simple, lose the cat with a bypass or straight through pipe, ended with a performance exhaust. these will have thousands spent in research and development, so the diameters should be spot on.
*makessubtlecommentthatUK-polos.netisn'treallyappropriateanymore*
Just kidding :wink: :lol:
Speedlaw
Moderator
Post by Speedlaw »
If you're throwing out the cat you do want to keep the lambda sensor, correct?
And is it still road legal in Poland then?
kz
Post by kz »
When I throwing out cat my lambda sensor can gave wrong signal to ECU - and I want to put in sport cat.
Speedlaw - road without cat is illegal in Poland.
KarlM
Post by KarlM »
Magnex do full systems inc manifold and cat if that makes a differnce
