[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Brake Pads - UK-POLOS.NET - THE VW Polo Forum
Treated myself to a new set of brake pads at the end of last week and set about fitting them this weekend. got the fronts done no trouble then when doing the rear pads i could not get the piston to go back in, and after speaking to an Audi mechanic mate of mine i found out that you can't! you need a special tool to do it! how rude! just another way of VW getting money out of u i guess!
yeah i've got greenstuff pads. From the driving i've done wit them so far they still give out dust, but that just might b cos it has been raining.
I've only done about 150 miles with them on the car so once they are properly bedded in i'll let u know how they are! First impressions are that they do have a better bite than the standard VW ones!
tom16v wrote:Treated myself to a new set of brake pads at the end of last week and set about fitting them this weekend. got the fronts done no trouble then when doing the rear pads i could not get the piston to go back in, and after speaking to an Audi mechanic mate of mine i found out that you can't! you need a special tool to do it! how rude! just another way of VW getting money out of u i guess!
Is that because you let it come out? Would it have been ok if you had kept the piston in?
the piston is out because that is what presses the pads onto the disk. even when you're not braking they do not fully return into the caliper, they just don't put pressure onto the pad. As the new pad is thicker than the one it is replacing it needs to go back or you cant re-assemble it! That's my understanding of it anyway!
Yeah, I know that, but why wouldn't it go back in? I have a clamp thing that my dad made out of ally which I use you wind it back in - link a mini g-clamp, but are you saying that you can't do that? I know its practically impossible to push it back by hand.
