New Rims?
New Rims?
'ow do all...
I've obsessively been looking at alloys the past couple of days now and I can't see past these ones...
http://www.topgear.co.uk/acatalog/4x_15 ... y_Whee.php
I really loved these rims when they first came out, and now I own a car I'm so tempted. Would these fit straight on? Im sure there's some other size requirement I need to know beforehand, but I know mines definately a 4 stud....that's about all I know
The above link is the cheapest I've seen so far too, so if they will fit do we all think they will suit?
I'll be photoshopping them later when I can be arsed!
Cheers all !
Cheers all !
Got em dude, they're rude rims, not to hard to clean either. got em with kumho (cant spell)195/45 r 15 tyres , makes such a difference compared to stock wheels and tyres. You feel the road more, but ya dont notice after a while.
I had trouble fitting the rear wheels, i bolted the wheels to the car, then went to put the center cap on, n it wouldnt fit over the bearing cap(ahhh), so i took the wheel off, prized off the bearing cap put the wheel back on, and the centre cap still didnt go on, so i ended up putting spacer on the rear wheels,(8mm i think).
Just ordered some bilstein lowering kit for it 60mm drop(should look ace), will post pics when it's on the car!
Oh , i def think they suit the car!
hope that helps!
Phil
hope that helps!
Phil
- bstardchild
- Moderator
Re: New Rims?
I'll help you on the technical bit so they fitDScape wrote:Im sure there's some other size requirement I need to know beforehand, but I know mines definately a 4 stud....that's about all I know
PCD 4 x 100 Thats 4 stud on a 100mm Diameter circle
Offset best to aim for ET 38 as thats std but.........
The lower the number the more the wheels will stick out......
I would guess if you wanted to fil the arches ET 30 would be max but I can't say for defo
Rim Width - max 7 inch if you are gonna put 195 tyres on it
Thanks for the replies guys!
I'm trying to understand the whole technical side of things, I will get my head round it one day! I've had a look on another site that were doing them 4x100 ET38 6.5" wide, so Im guessing they'll bang on no problem at all? Will I need spacers? ...hark at me being technical now!
Phil, I'd love to see some pics of yours matey, that would be awesome.
Glad of the positive comments so far. I can't really afford them, but I ain't thought of anything else all day. My way of thinking is if I aint gonna get them now, Im only gonna get them one day so why wait!
Definately getting them though, just getting the balls to make the payment
Re: New Rims?
One important info... CENTRE BORE= 57.1 (mm I should think)bstardchild wrote:I'll help you on the technical bit so they fitDScape wrote:Im sure there's some other size requirement I need to know beforehand, but I know mines definately a 4 stud....that's about all I know
I made the mistake of buying some wheels off another car and the centre doesnt fit on... be careful when buying wheels off another car.
Anyone know good cheap places to get the wheels bored? (Prices anyone? ) London/North/East of London preferrable.
- bstardchild
- Moderator
Re: New Rims?
Well spotted...... ThanksJTLondon wrote:One important info... CENTRE BORE= 57.1 (mm I should think)
yeah those will be spot on, you could really slam the polo with those as the rear tyres should fit under the arches.DScape wrote: 4x100 ET38 6.5" wide, so Im guessing they'll bang on no problem at all? Will I need spacers? ...hark at me being technical now!
personally I would say spacers would be needed though. I have et35 on 7 inch rims. so they're approx 10mm further out. the backs just fit in, and the fronts are fine. so 8-10mm spacers would do the trick if you really wanted the wider stance.
Re: New Rims?
a 195 is fine on an 8"bstardchild wrote:Rim Width - max 7 inch if you are gonna put 195 tyres on it
Pretty hard not to spot when you've got yourself wheels with 54.1mm bore and they dont fit on the polo LMAO *goes into a frenzied breakdown*bstardchild wrote:Well spotted...... ThanksJTLondon wrote:One important info... CENTRE BORE= 57.1 (mm I should think)
I hear spaces are quite dangerous to have... whats worse using spaces or putting on the wheels without them?david burton wrote: yeah those will be spot on, you could really slam the polo with those as the rear tyres should fit under the arches.
