Buying a GTi
ModifiedMadness
Sponsor
Buying a GTi
Post by ModifiedMadness »
Well, in the next month or sooner with a bit of luck, I'm hoping to get a GTi, what does everyone class as high mileage etc on one, or are these the kind of cars where mileage doesn't matter to a degree?
Also feel free to add any other things to look out for except the obvious check for the Pedal Box Recall work being done.
Tom
andyg
Post by andyg »
The main bits of a GTi engine come from previous well proven VW engines, so the engine itself should last you very long (assuming you look after it and it hasn't been thrashed constantly).
I hear the gearboxes and clutches aren't great on the GTi, I think it depends a lot on how you drive.
The youngest GTi you will find is going to be at least 3+ years old so I'd say the average milage you should be expecting on most of the Gtis you see are going to be 40,000 to 50,000.
Like i said, if you find a well looked after GTi and you look after it yourself you should easy see 100k.
Don't think milage is a huge issue, only takes a few hundred miles of bad driving to mash up an engine.
Make sure the brakes dont bind, make sure the a/c works and the headlight washer jets. Pedal box recall code should show up as 30CI in the log book.
PhilGTi
Post by PhilGTi »
Mileage is only an issue on resale, they are fine upto 100k+, just look for one with 40-50k tbh. Then you should get a bargin and a car that will sell easy. Look for low previous owners also, otherwise it might have been thrashed alot then sold on...
Phill.
ModifiedMadness
Sponsor
Yeah thanks, that's what I'm doing I did find one with 3 previous owners, so closed that straight away. There's a nice one I've found, just gotta wait for the money to come through.
PhilGTi
Post by PhilGTi »
I wudnt bother looking until you have the money in your hand, GTi's dont stick arround long if they are good, every1 i went to see sold in a few days, even the s**t ones.
Phill.
ModifiedMadness
Sponsor
That's exactly what I thought, you can gurantee it'll be gone when I get the money through
ModifiedMadness
Sponsor
This is what I plan for it once I have one - Thanks to PoloSilver for the picture, maybe not quite as low as that, all depends on cost and ease of the job. Just general smoothing and a bad boy bonnet.
PhilGTi
Post by PhilGTi »
You got some photoshop skills.. i made one very similar to that myself!
Phill.
ModifiedMadness
Sponsor
Yeah quite like playing around on Photoshop
elephant
Post by elephant »
I have just test drive a 2nd hand Polo GTI (2001), the engine sounds a bit noisy at 1000rpm (idle) is it normal?? Beside the padal box, timing belt and the above, what other things should I look into????
thank you experts,
Cheers,
Dave
PhilGTi
Post by PhilGTi »
When idle at 1,000rpm i cannot hear my engine... sounds like a slight background noise!
Phill.
elephant
Post by elephant »
Thanks, Phill.
Anything else I should play attent to a 2nd GTI??
