Speed Pulse Wire
Speed Pulse Wire
Im currently deciding if i should get a gti or not, one of the things i want to do is put a avic-x1r headunit and needs a clamp on the speed pulse wire which can be in the loom somewhere.
- Sponsor
Re: Speed Pulse Wire
At the fusebox there is a white connector G1. Pin 11 carries the signal. OR: Diesel engine cars, there is a Hall generator at the gearbox with 3 cables: Black, Brown/Green and White/Blue. The white/Blue cable carries the signal.dunstable_gti wrote:Im currently deciding if i should get a gti or not, one of the things i want to do is put a avic-x1r headunit and needs a clamp on the speed pulse wire which can be in the loom somewhere.
Cheers Ian
