has my pedal box gone?
theclient
Post by theclient »
right ... fitted new front pads on thurs (14th) ebc greenstuf ...
they take 200miles to bed in ... so
on saturday im going down a road soing bout 65 and start braking for a roundabout then realise i have to brake a bit harder than i thought (trying not to mess up the new pads/old discs) then i heard this sort of clonk noise and felt it throught the brake pedal, i pulled over and had a look just to see if i could see anything .. pads maybe?
but no ... the car still drives fine no change at all!
could the pedal box have gone???
cheers
gareth
PhilGTi
Post by PhilGTi »
The pedal box only effects the clutch pedal, not all 3, so no!
Phill.
moynas
Post by moynas »
Welcome to the world of ABS mate! On heavy braking you will feel the brake judder or even lightly clunk!!
CBurns
Post by CBurns »
not to worry you but shortly after getting my pedal box replaced i had to brake hard and i heard a load snap and the pedal shot forward.
Brake lights always remained on after it happened though took it back to VW and they said it was a faulty brake pedal it had snapped when i asked to see it.
id check to see if you've got the same problems. When it had happened i could pull the pedal back towards me.
Chris
theclient
Post by theclient »
ahhh cheers for your help!
i think it was the abs kicking in come to think of it? as our polos have these little pedal niggles i just assumed it would be a problem rather that the abs ... oh well
... and yeah ill check the brake pedal for play too
