my GTI.
Was wondering if anyone know what to input?
Mine is ARC and FFW,but it seems need to put some number theremoynas wrote:You need to put in AVY and FFW!!
Good luck the programs massive!
Yes, I did the same...moynas wrote:You can also type your full chass number in aswell that might help!
For me to get into elsa win i put in v for volkswagen (bit obvious)
Then i put in 2001
Then 6n2
Then select avy from the engine bit (or whatever your engine is)
Then select FFW from the gear box bit (FFW type M 085H)
And that should let you in! i dont use the internet connection bit no need really!
Just got it done today, it's the matter of installation steps.doug&dan wrote:i'm getting the same messege! its a pain in the arse!
when i put the chassis number in, and search, brings up a new window but page can't be displayed or summit like that comes up!
