amstrange1 wrote:How healthy are the top mounts?
Both top mounts are brand new from ECP.
amstrange1 wrote:Is there much/any play in the suspension components when you jack the car up?
No play in any of the suspension components, appart from steering wheel feel.
amstrange1 wrote:What condition are the anti-roll bar mounts in?
Roll bar mounts are those solid green type ones, from a Polo Cup car???
amstrange1 wrote:If the steering column seems to be "clunking" and there's some play in the steering I'd check your steering column pinch bolt. These tend to come undone over time.
Where is the pinch bolt situated & what will i need to tighten it up with?
amstrange1 wrote:I guess you're just going to end up checking stuff over in a systematic manner, and replacing anything that's suspect to get to the bottom of it. At least you know your tracking and wheel balancing are sorted though!
Believe me, i have replaced almost everything i can think could be related to the vibration situation
