Air box unit
deathhour
Air box unit
Post by deathhour »
I've heard you can put a golf mk2 or mk3 gti afm and air box into the polo gt ? does this make any difference? I found much more golf afm on ebay and wanted to buy one because I lost my original :(
by the way fitting a K & N induction kit without a afm cause overfuelling? because my gt engine is overfuelling like crazing after the conversion even though I'm using a 1.0 5 speed gearbox and not the short ration gearbox orginally on the 3f engine?
Any suggestions welcome!!!
Tahrey1043
Post by Tahrey1043 »
jeez, hey, what now?
how is fitting a different gearbox going to do anything to your fuel air mixture? come down off the sugar rush dude and ask again :)
i remember a fancy for golf air intake conversions about a year ago, not sure what happened on that front, it kind of fizzled.. think a few people round here have them though so keep asking. Don't think they're GTi ones however, just plain mk3 golf things.
pete69zx
Post by pete69zx »
doesnt the spring position need to be adjusted on the golf airbox if i remember correctly :?:
pettsy
Moderator
Post by pettsy »
as far as i know, mk2 golf gti airflow meters are a direct replacement for a mk3 gt one, however i think they tend to work better on some cars than others.main difference is a bigger bore i think.hardhitter will know for sure!
Pettsy
mickb
Post by mickb »
deathour, you saying you've just got a K&N on the end of the induction pipe with no AFM, how does that work???
calvino
Post by calvino »
mickb wrote:deathour, you saying you've just got a K&N on the end of the induction pipe with no AFM, how does that work???
i bought mine like this it ticks over badly, so put the afm and box back on runs well now just how the factory intended!!
deathhour
Post by deathhour »
yeah I had no afm for the last two weeks, only a k&n filter. it worked sort of because I bought a performance resistor off ebay and stuck it in the wires harness where it should have pluged into the afm. don't recommend doing that :)
deathhour
Post by deathhour »
yes think I just sorted out my overfuelling problem now, just fitted a golf atm with a K&N filter, had to adjust aload a things; spring inside the afm, co2 screw and the idelling screw on the throttle body.
Wouldn't have know what to do if I wasn't on this forum or porka, very useful sites.
Must of been running a rich mixture when I had the resistor in lol. But hopefully fuel consumption will be normal now, now I have the golf afm and tuned it to my satisfaction. :) idelling's good now because when I put the golf afm without any adjustments it was hunting very badly.
Had to lossen the spring inside the afm and adjust the co2 settings a bit. Might put up some pictures when I my card reader back.
mickb
Post by mickb »
pics would be good, I ve been thinking of a golf AFM for a while. I think there was also another way by puting the GT stuff in the golf |AFM, not sure thou
optima21
Sponsor
Post by optima21 »
yeah you can fit the gt internals into a golf afm, thats what I've got in mine now, but once you know how to adjust a golf afm it works just as well as I've got a standard golf afm too.
