i also advise you to get the stainless flexi`s ( i use omp)
at the moment (this is not on a gti so i dont worry about rear disks
galfer drilled and grooved disks
omp road and sport pads stailess flexi`s
belive me when i say that i can put you on the windscrean (the vw sales man did ones on a test drive*)
but when i had the road and sport pads on the standard discs and standard susp (+ front upper strut brace) i used to be able to touch the front bump on the floor under heavy braking
a little word of advice though. when i did all my braking upgrades i didnt think about the chassis, this was more of an oversight that i thought it might be, when pushing the braking system to its limits the back end has a tendancy to "sway" (feels like your fishtailing) this tends to make most passengers feer for their life, its also a little tricky to control the first few times. the way i solved this was to fit a lower front strut brace (kinda also doubles as a sump protector (till i get my real one on
* went to vw to get the gear box play checked out and at the start of the test drive i told him not to worry and that i didnt mind if he caned it a little as the engine and tyres were already fairly hot. he accelerated to about 45 mph and then remembered that the original brakes were kinda crappy, in other words " he literally jumped on the pedal". he forgot to put on his seat belt and thus got thrown foreward ,,, and into the windscrean, leaving a big splat that i had to clean. but oh was it worth it
