Boot Install
knaps
Boot Install
Post by knaps »
Just thought I would share my idea of a boot install for my Polo. I'm thinking of building a MDF box that covers the entire surface of the boot, and about 7 inchs deep, mount the amp on the boot floor and have a perspex window to 'view' the amp and mount two 10 inch sub woofers either side in the box. Only thing is that it will all have to come out to retrieve the spare........
Randall
Re: Boot Install
Post by Randall »
knaps wrote:Just thought I would share my idea of a boot install for my Polo. I'm thinking of building a MDF box that covers the entire surface of the boot, and about 7 inchs deep, mount the amp on the boot floor and have a perspex window to 'view' the amp and mount two 10 inch sub woofers either side in the box. Only thing is that it will all have to come out to retrieve the spare........
currently working on mine at the mo...
work has come to a halt tho as got me holiday coming up so all shall be revealed in a month or so
Rich
Jillwilson
Post by Jillwilson »
Or why not just remove the spare and put in a foam kit somewhere else plus it means more space for you to modify.
x
Randall
Post by Randall »
Jillwilson wrote:Or why not just remove the spare and put in a foam kit somewhere else plus it means more space for you to modify.
x
see Jill knows the way fourth > already done that :wink: can of tyreweld is in the motor instead
Jillwilson
See I'm not totally daft.
x
