fault codes
forbezGti
fault codes
Post by forbezGti »
hi guys need some help.
every time i plug in vag com in my car this one
fault code keeps coming up. its a camshaft timing code.
can anyone help. cheers
jimmadee
Post by jimmadee »
Is it code 'G40' ( yes i know ..)
I had to replace cam sensor & speed sensor due to no communication to ECU.
Sender 030907601B 19.42
Sender 030957147G 53.71
Parts + Labour £153
smokeGTI
Post by smokeGTI »
Hi guys,
I'm new to VAG-com, and I saw an ABS issue for the control unit
# 6Q0-909-605-A.
http://www.ross-tech.com/vag-com/vw_issues.html#Airbags
Does that affect our POLO GTI?
Do you guys use Auto scan without problem?
Yeh, I'm just too lazy to dig it up and check the number. :lol:
HK 6N2
Post by HK 6N2 »
Yes, I got the same error code" camshaft timing code"!!
What is the influence of this error code?? :roll:
HK 6N2
Re: fault codes
Post by HK 6N2 »
forbezGti wrote:hi guys need some help.
Would you mind to tell me what you feel different about the car after
found this fault code?? :roll:
