Foggys
polocoupcl
Foggys
Post by polocoupcl »
Oppinions on them cheers.
robz
Post by robz »
im not 2 keen on them to b honest. i prefer the proper mk3 fogs. jst my 2p worth tho.......
pettsy
Moderator
Post by pettsy »
not too keen wither.would look better IMO if you fitted them into where the fogs normally are :idea:
Karl_CLCoupe
Post by Karl_CLCoupe »
Maybe if you were able to move them further into the corners of that 'vent', it might look a bit better? I think its them being quite close together thats doing it. Ultimately though, its up to you. If you like it, you stick with it :D
Karl.
polocoupcl
plan was to fit in the origional cut out for the fogs but the brackets that came with the fogs wouldnt fit on the mounting bit :(
Fitted them wider apart but had to fit to the bumber so that meant they shook all the time and looked pants when lit.
pettsy
Moderator
Post by pettsy »
when i refitted the fogs on my old gt, i made some brackets up out of perspex that i araldited to the bumper :wink: its easy peasy when you take the front bumper off, you just have to make sure they're directed in the right place before the glue hardens! 8)
