Smoke :s
neilw
Smoke :s
Post by neilw »
Ok, so this has happened twice now in the last month or so. Turn on ignition, and smoke comes from behind the steering wheel, from where all the indicator stalks go. tune off my ignition and it stops, turn on again and everythings ok. everything works ok. It deffinatly smells electrical. Happened to anyone else? should i get it checked out?
Cheeres Neil
inder
Post by inder »
:shock: defo get it checked out m8! perhaps some loose connection causing some kind of short or a dodgy component
smoke = bad surely :)
ModifiedMadness
Sponsor
Post by ModifiedMadness »
What he said,get it checked out before fire comes out of there when you turn it on!
LAN's GTI
Post by LAN's GTI »
awesome gti nick
hiya
Post by awesome gti nick »
i had that problem with my polo gti it was the indicator switch burning out cost about £90 with fitting
neilw
Post by neilw »
Thanks for that, It has'nt happened again since (touch wood) If it does it again then it'll be time to get it looked at. I will bear in mind all of these posibilitys. Thanks Neil
