Des, you're right about the torque being the issue, although not at the wheels.
Your clutch takes a bit of a hammering, so with must of this style of upgrade, you should factor in an upgraded clutch too...
Not sure that a panel filter is going to help matters too much either. The jury is very much out as to whether the oiled filters eventual mess with your MAF... that could be another £200 if it goes west.
Add to that the fact the there's a turbo spinning away there, and you would need an especially badly caked filter for it not to get enough air through the system. Most of the guys I've spoken to and the evidence from dyno tests show little to no increase in power with a k&n on a 130TDi.
Sorry to pee on your parade, but this is all things that I've had to consider since Upsoluting my Passat.
Mind you, the fun that can be had as you spin your wheels in third is something else...
