quick question about headlight switch
polonuts
Post by polonuts »
can someone please tell me if the headlight switch should be permenantly illuminated?
I have converted mine to blue LED and cant remember when it is supposed to be illuminated :(
At the moment the light is off with ignition on, on with side lights and off with the dipped beam.
pettsy
Moderator
Post by pettsy »
think its normally faintly on with ignition,on with sidelights and off with dipped beam.
hope that helps
Pettsy
Tahrey1043
Post by Tahrey1043 »
mine:
switch off = always off
sidelights on = always on
headlights on = off with ignition on, on with ignition off
polonuts
Post by polonuts »
thanks I think I have sorted it out:
Ignition on: Bulb sign Illuminated
Sidelights on: Bulb sign Illuminated
Dipped beam on: Bulb Illuminated
Don't know if its right, but everthing seems to work OK so I'm not going to fuss around anymore!!
Tahrey1043
doesnt sound right mate... does the bit in the middle not come on at all?
hardhitter
Moderator
Post by hardhitter »
polonuts wrote:thanks I think I have sorted it out:
Thats correct
polonuts
Post by polonuts »
Phew thank god thats right. The light in the centre only comes on with the side lights and goes off when dipped is on, but thats not a problem to me. Thanks to everyone for putting my mind at ease :wink:
Tahrey1043
sorry, misread before :)
you've got it sorted :D
pettsy
Moderator
Post by pettsy »
Tahrey1043 wrote:sorry, misread before :)
same here, confused between bulb sign and green led :oops: :wink:
Karl_CLCoupe
Post by Karl_CLCoupe »
While on the subject of headlight switches and bulbs...
Anyone have any idea how to replace blown bulbs? The bulb symbol on my headlight switch has never lit up since I've got the car, and I would like to have it working again (call it podantic I know!).
Karl.
Tahrey1043
hehe guess mine must have blown sometime in the 90s then, i never knew it was even supposed to be lit until now!
polonuts
Post by polonuts »
Karl_CLCoupe wrote:While on the subject of headlight switches and bulbs...
Karl.
Hi mate you have 2 choices, either replace the entire switch assembly or arm yourself with a soldering gun, open the switch (four clips hold it together). There are 2 bulbs one higher than the other. The highest bulb is the one that has blown on yours. You then have two further options, replace the blown bulb with another known bulb from a doner switch (any of the dash switches will do), or replace it with an LED and resistor, There is a post on this forum on how to do this and when I find it again I will post the link on this thread.
Hope this helps :wink:
Karl_CLCoupe
Thanks for your help. Might look at a new switch, as mine has a rattling noise inside it when I've had to remove it to get to the clips for the clocks. That and it can be hard to get the headlights on sometimes, as it seems to jam on sidelights.
Karl.
Tahrey1043
it comes apart?
might actually possible to rejig it to activate the foglight switch circuit on the sidelights then?!
polonuts
Post by polonuts »
anything is possible, but why would you want to take the switch apart? Why not just link the fog light circuit to the side-light circuit??
