Page 1 of 2
quick question about headlight switch
Posted: Sun Oct 02, 2005 1:09 am
by polonuts
can someone please tell me if the headlight switch should be permenantly illuminated?
I have converted mine to blue LED and cant remember when it is supposed to be illuminated
At the moment the light is off with ignition on, on with side lights and off with the dipped beam.
Posted: Sun Oct 02, 2005 4:27 pm
by pettsy
think its normally faintly on with ignition,on with sidelights and off with dipped beam.
hope that helps
Pettsy
Posted: Sun Oct 02, 2005 6:35 pm
by Tahrey1043
mine:
switch off = always off
sidelights on = always on
headlights on = off with ignition on, on with ignition off
Posted: Sun Oct 02, 2005 6:56 pm
by polonuts
thanks I think I have sorted it out:
Ignition on: Bulb sign Illuminated
Sidelights on: Bulb sign Illuminated
Dipped beam on: Bulb Illuminated
Don't know if its right, but everthing seems to work OK so I'm not going to fuss around anymore!!
Posted: Sun Oct 02, 2005 7:28 pm
by Tahrey1043
doesnt sound right mate... does the bit in the middle not come on at all?
Posted: Sun Oct 02, 2005 7:48 pm
by hardhitter
polonuts wrote:thanks I think I have sorted it out:
Thats correct
Posted: Mon Oct 03, 2005 10:26 am
by polonuts
Phew thank god thats right. The light in the centre only comes on with the side lights and goes off when dipped is on, but thats not a problem to me. Thanks to everyone for putting my mind at ease
Posted: Mon Oct 03, 2005 9:18 pm
by Tahrey1043
sorry, misread before
you've got it sorted
Posted: Tue Oct 04, 2005 7:13 pm
by pettsy
Tahrey1043 wrote:sorry, misread before
same here, confused between bulb sign and green led
Posted: Wed Oct 05, 2005 10:18 pm
by Karl_CLCoupe
While on the subject of headlight switches and bulbs...
Anyone have any idea how to replace blown bulbs? The bulb symbol on my headlight switch has never lit up since I've got the car, and I would like to have it working again (call it podantic I know!).
Karl.
Posted: Wed Oct 05, 2005 11:47 pm
by Tahrey1043
hehe guess mine must have blown sometime in the 90s then, i never knew it was even supposed to be lit until now!
Posted: Thu Oct 06, 2005 1:03 am
by polonuts
Karl_CLCoupe wrote:While on the subject of headlight switches and bulbs...
Karl.
Hi mate you have 2 choices, either replace the entire switch assembly or arm yourself with a soldering gun, open the switch (four clips hold it together). There are 2 bulbs one higher than the other. The highest bulb is the one that has blown on yours. You then have two further options, replace the blown bulb with another known bulb from a doner switch (any of the dash switches will do), or replace it with an LED and resistor, There is a post on this forum on how to do this and when I find it again I will post the link on this thread.
Hope this helps
Posted: Thu Oct 06, 2005 1:52 pm
by Karl_CLCoupe
Thanks for your help. Might look at a new switch, as mine has a rattling noise inside it when I've had to remove it to get to the clips for the clocks. That and it can be hard to get the headlights on sometimes, as it seems to jam on sidelights.
Karl.
Posted: Thu Oct 06, 2005 10:31 pm
by Tahrey1043
it comes apart?
might actually possible to rejig it to activate the foglight switch circuit on the sidelights then?!
Posted: Fri Oct 07, 2005 1:51 am
by polonuts
anything is possible, but why would you want to take the switch apart? Why not just link the fog light circuit to the side-light circuit??
