Hi rob, you just lift up the gator then you`ll see a gold clip that holds the gearknob onto the shaft i just snipped that off then the gearknob just pulls off, HTH
Dazza
DAZZA_TDI wrote:Hi rob, you just lift up the gator then you`ll see a gold clip that holds the gearknob onto the shaft i just snipped that off then the gearknob just pulls off, HTH
Dazza
cheers buddy, i was wondering how to do it aswell..
inder wrote:How about removing the actual knob from the gaitor?
I know the gold clip releases the whole lot from the gearstick, but the knob is still firmly attached to the gaitor
any ideas?
I had to cut the gator where it joins onto the gearknob then squeeze the gator up into the new gearknob and then tighten with the allen key, it was fiddly but i managed to get it right
Dazza
