Heaters/ac only working on Speed 4 On Gti
my Heaters only working on Speed 4 On my polo Gti 2000 model. 1,2,3 are dead been told its a resistor pack? anyone ever fitted one? where do they go? vw want 40 for the part!!!
If you go into the passenger footwell, peal back the foam gently, and then you will see a few screws on the far left, take them out and the bottom of the fan unit comes off. The pack is in there its a green coily resistor type thingy about 2 inch long. You unscrew it, pull the leads off and then reverse what you just did after bunging the new one on.
Bet you can't get the foam back in a fashion where it stays back!!!
