suspension
cammie
suspension
Post by cammie »
anyone give some advice on a suspension kit to lower my 1.9tdi about 40mm? springs , fullkit or coilovers??????????
Harald73
Post by Harald73 »
I recommend Eibach Sport-System fullkit. It lowers 45-50mm front and 30-35mm rear. For more information click here!
That don´t make your car look like it´s about to fly like many kits with equal lowering in front and rear. To see my car with Sport-System click here and here.
M7
Post by M7 »
i did apex springs by 40mm and it sits nicely on 17s. but a little too high for my liking on 15s
carmadaaron
Post by carmadaaron »
btw, does yours rub? and where do they rub?
u on 215/45/17 rite?
M7
Post by M7 »
only on proper full lock to the left when going up on the drive.
the screws in the arch lining caught, but i just took em out and they are fine.
im on 195/45/15 for a few months now tho 8)
i thought 17s were good for handling! :shock: but these are amazing! :lol: im takin some corners 20mph faster now
carmadaaron
dont suppose u can take a pic of the area it rubs? :D (on 215/45/17 when it rubbed btw?
im considering some -50mm up front :idea:
cheers
andrewg450
Post by andrewg450 »
Hi all,
I am thinking about buying a new set of wheels for my polo and also want to get the car lowered. I have been looking at some pics from a german website and really fancy a set of wide 16's and getting the car as low as possible. I was therefore wondering if anybody could give me some advice on the best way to do this. I don't want to spend a fortune.
Any advice would be grate. I know that coil overs are probably the way to go,but would like to hear from those of you who have had springs fitted.
Cheers,
Andy
M7
Post by M7 »
arron, run your hand along the inside of your arch and you will feel small screws holding the lining in place (the black plastic which stops all the s**t going inside the chasis)
i just took 2 on each front arch out. il get some pics if i can tho
andrewg450...
this is my car dropped 40mm on 17's and then on 15's. 16's will sit somwhere in between. hope that helps.
my opinion, if running 17s 40-50mm springs will do fine. if the rims are going to be smaller i would go for coilovers
