WHY ONE WHEEL WONT FIT
rustypolo
Post by rustypolo »
HI ALL
IVE BROUGHT A SET OF WOLFRACE WHEELS THAT WERE ON A MK2 GOLF THREE WHEELS FIT APART FROM THE DRIVERS SIDE IT CATCHES ON THE SPRING THE TYRES ARE 195/50/15s SHOULD I SPACE THEM OUT AND TRIM THE ARCHES OR HAS ANYONE ELSE GOT A SUGGESTION
hardhitter
Moderator
Post by hardhitter »
The tyres are too big for a start. They need to be be 195 45 15. You need to have a suitable offset too. You will more than likely need to trim the arches too.
Not worth it when they spoil the handling imo.
and
Turn your caps lock off !
SteB
Post by SteB »
Remember, the drivers side has more weight on it - i.e. drive, steering column, dashboard odds and sods etc so you will need to sort the whole setup out properly - probably by doing just what Hardhitter says!
