15" wheels will they go? and rear washer jet problem
PoloGti_88
Post by PoloGti_88 »
hi peeps, quick questions i want to ask. will ET27 PCD100 fit my polo gti alright? with 195/45/15?
also my rear washer doesnt seem to be squirting out any water, but front ones are fine? any solution or tips i can use thanks :)
mikegti
Post by mikegti »
Your rear washer hose has probably popped off, either behind the trim next to the passenger side rear seat (3 door) or in the actual tailgate itself.
There are quite a few posts on this so have a quick search...
loud
Location: 25 miles south of Aberdeen Drives: 9N3 Polo GTi
Post by loud »
mine split in both places :x
PoloGti_88
oh no, forgot to mention to i`ve got water leakage in my boot =s maybe that might be the reason :cry:
PoloGti_88
so does anyone know if a set of ET 27 pcd100 will fit my polo gti, am unsure as normally ET 38 are better right? cheers
vdubit
Post by vdubit »
what width are the wheels? 7j or smaller should be ok (assuming your not lowered lots) but may scrub the front on half lock. Bigger than 7j will definetely scrub on half lock. The rears should be ok if your not too low, else they will no doubt catch the outside arch. (just attack it with a hammer, it works)
