[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Passenger inner Door Cover Removal - UK-POLOS.NET - THE VW Polo Forum
carmadaaron wrote:if you check out the DIY section of the forum, theres 2 pdf files that tell you what to do. one guide is for the fronts, the other one is for rears.
Found them thanks!, if I wanted only to remove the door handle (inside) would I need to remove the complete panel or there is a way to just remove the handle?
6-8 start shaped screws at the bottom of the door card
one big normal screw in the door handle that brakes into 2
then the horse shoe clip on the window winder
I have power windows, will it be the same?
i said that is for MANUAL windows. the door handle is in a different place so obviously not the same
