Problem with my Angel Eyes
- Location: Hertfordshire Drives: Ford Puma 1.7 Enjoys: Mowing grass
I've just noticed that my Angel Eyes on my car have suddenly been popping around the edges (the sidelight rings)
i can't explain why or how, but theres supposed to be a ring of light right around ok, and it seems very dim in places now and in other places theres no light at all
i don't know what to do
All i know is FK make them and they are getting worse
any advice would be great
-Ben-
-Ben-
- Sponsor
So what you're saying is that the LED rings (sidelights) are being blown?
And instead of a steady glow all around the edge it's patchy. I'm presuming that they are LEDs that are used for the angel eye effect?
Can't help I'm afraid, I don't dabble with the electrics on my car but I just wanted to try and help make things clearer for anyone with some technical knowledge
Hope you can fix them! Or send them back to FK?
- Sponsor
Re: angel eyes
ok cheers for the pointers will check them out
-Ben-
They don't sidelight 5W or filament,don't fit in the ring...The leds look like rear lamps led,it isn't yellow,somebody changed different colour (generally blue) in Turkiye but I don't...In my opinion you should changed it if under warrenty...carmadaaron wrote: they dont look like LEDs to me, theyre far too yellow, unless they are yellow leds , more like filament bulbs to me.
if they are the same as the normal sidelight bulbs then they are W5W ones...
