Just fitted my sub and amp! But theres too much bass!!
I have just finished installing my sub and amp to my9n. Once it was wired up I turned on the head unit and...BOOM! Theres the base, a shedload of it!!
To try and solve this i turned down the subwoofer settings on my headunit, despite doing this the bass is still over powering my new component speakers. Will i need more speakers to overcome this or is there something im doing wrong?!
- Sponsor
SPECIFICATIONS
AMP
Power Output: 97 Watts RMS x 2 channels at 4 ohms and ≤ 1% THD + N
145 Watts RMS x 2 channels at 2 ohms, 14.4V supply and ≤ 1% THD + N
290 Watts RMS x 1 channel at 4 ohms, 14.4V supply and ≤ 1% THD + N
Signal-to-Noise Ratio Signal-to-noise ratio: 82dBA (reference 1 watt into 4 ohms)
Dynamic Power: 190 watts at 2 ohms
Effective damping factor: 6.39 at 4 ohms
Frequency Response: 10Hz – 90kHz (–3dB)
Maximum input signal: 5.5V
Maximum sensitivity: 230mV
Output regulation: 0.098dB at 4 ohms
12dB Built-in, variable, low-pass electronic crossover
One pair full-range preamp outputs
Separate high-level and low-level inputs
AMP
SPEAKERS
17cm Type-S component speakers
Peak Power 250W
RMS Power 50W
Frequency Response: 35Hz - 30kHz
Spoke Design Grill System
Multi Layered Cone
Wave Guide
Linear Drive MagnetTM
1" soft Dome Tweeter With Installation Kit
External Crossover With Tweeter Protection
Lightweight Air-Injected Rubber Edge
Neodymium Tweeter Magnet
Custom Fit Spacer
Nomex Spider
The sub and amp are JBL and the speakers are Alpine
Peak Power 250W
RMS Power 50W
Multi Layered Cone
Wave Guide
Custom Fit Spacer
Nomex Spider
- Sponsor
- Sponsor
- Sponsor
- Sponsor
Didn't rattle the boot, watch this though to see what it done
http://www.realmofexcursion.com/videos/ ... se12.5.wmv
- Sponsor
