The only switch i see which turns the lights on is the one on the right side of the steering wheel but that doesn't appear to be dipped beam, do mk2's even have dipped beam
Other thing is if you've got the headlights off and pull the stalk it does a flash while the stalk is back. The downside is, when you turn your headlights on later, you'll be on full beams until you pull the stalk again.
