just wondering, has anyone had the problem of their doors "dropping" (falling out of allignment witht the doorpin?) It seems to be the hinges have dropped/moved somehow. Is this a common prob (its happened 2 a few of my polos) & any1 no how i can fix it?
cheers Robz
door hinges
BLACK6N_POLO
nah i dont, tho ive no idea how its been treated over the last 13years or so....do you leave ur doors open for long periods of time -- not unclocked but the door open with the hinges holding the weight of the door -- this could cause the door nt to hang properly and there might be ur prob
cheers matei've heard it's a common problem mate, don't know how to fix it but i'm sure i read a guide somewhere a while back, i'll try and find it
sorry robz, can't find it now
but my haynes manual tells you how to adjust it.
Section 11:5
1.open door, prise off special washer and remove check strap pivot pin.
2. mark position of brackets in relation to each other.
3. support the door and unscrew and remove lower hinge bolt followed by upper and take door off.
refitting and adjustment
4.refitting is a reversal of removal, but if neccessary adjust the position of the door on the hinges so that, when closed it is level with the bodywork, lube the hinges with oil and check strap with grease, if neccesary adjust the position of the door striker.
hope this helps
Section 11:5
hope this helps
hardhitter
- Moderator
