So I went a bit nuts taking photos, hope you like!
Spec:
OWNED SINCE March 2000
ENGINE
1272cc, multipoint injected, supercharged; Pitstop Developments Full Blend Supercharger; SNS Stage 5 chip; Bosch 250cc "Green" Injectors; 68mm alloy pulley; Polo GT inlet manifold; De-restricted airbox; Boost return pipes removed; Pitstop Developments aluminium oil catch tank; Longlife stainless steel exhaust with decat pipe;
SUSPENSION
Spax Adjustable rate dampers; -40mm Spax Springs; G40 cup car style Polyurethane anti-roll bar block mounts; Bonrath polyurethane shocker bushes (rear); Steel Front Brace Bar; Polyurethane bump stops;
BRAKES
Stock G40 calipers and carriers (painted silver); Raicam pads; Brembo discs; Pitstop Developments Steel Braided Brake Hoses;
WHEELS AND TYRES
15x6.5 Adikt Speed wheels; 195/45 Good Year Eagle F1 GSD3 Tyres;
ELECTRICAL
Uprated headlight and foglight wiring looms; Philips Vision Plus headlight bulbs; Xenon foglight bulbs; Duostyling Air/Fuel meter;
EXTERIOR
Clear indicators; Late spec rear light clusters; OE Fog Lights; de-locked door handles; Wing Aerial Hole smoothed;
INTERIOR
Corrado VR6 Leather Steering Wheel; Scirocco GTX Gear Knob; Leather Gear Gaiter; Scirocco GT2 "Modekaro" trim;
SECURITY
Toad Ai606 CAT1 Alarm and Immobiliser;
