ECU reset?
Ant_43
ECU reset?
Post by Ant_43 »
I'm thinking of disconnecting the battery on my Gti to reset the ECU and see if it makes the car run a bit smoother. This has probably already been answered here but just wanted to check:
How long should i disconnect for so that the ECU resets?
Will my radio still work (read something here about a security code)?
Any help much appreciated
ceedubya
Post by ceedubya »
its alot easier and safer to take the ecu relay out of the fuse board, saves the carry on with radio codes etc
i cannot remember the relay number at the mo tho :roll:
HK 6N2
Post by HK 6N2 »
Is it safe to reset the ECU?? :roll:
ceedubya
Post by ceedubya »
its safe to reset the ecu
the relay number is 100
HK 6N2
Post by HK 6N2 »
ceedubya wrote:its safe to reset the ecu
Where is that relay locate in??
ceedubya
Post by ceedubya »
i aint 100% sure but i would look on the main fuse / relay board 1st
its alot easier to pull the relay than disconnecting the battery to do a reset, no need to worry about radio codes etc
