ECU reset?
Posted: Tue Jan 31, 2006 10:24 pm
by Ant_43
I'm thinking of disconnecting the battery on my Gti to reset the ECU and see if it makes the car run a bit smoother. This has probably already been answered here but just wanted to check:
How long should i disconnect for so that the ECU resets?
Will my radio still work (read something here about a security code)?
Any help much appreciated
Posted: Wed Feb 01, 2006 12:42 am
by ceedubya
its alot easier and safer to take the ecu relay out of the fuse board, saves the carry on with radio codes etc
i cannot remember the relay number at the mo tho
Posted: Wed Feb 01, 2006 1:37 pm
by HK 6N2
Is it safe to reset the ECU??
Posted: Thu Feb 02, 2006 2:53 pm
by ceedubya
its safe to reset the ecu
the relay number is 100
Posted: Thu Feb 02, 2006 3:08 pm
by HK 6N2
ceedubya wrote:its safe to reset the ecu
Where is that relay locate in??
Posted: Thu Feb 02, 2006 4:21 pm
by ceedubya
i aint 100% sure but i would look on the main fuse / relay board 1st
its alot easier to pull the relay than disconnecting the battery to do a reset, no need to worry about radio codes etc
