as above
1: how do i get into my headlights to change my sidelight bulbs?
2: where do i buy the black vw badge from and whats the best advice for fitting it
3: demon tweeks qouted me bout 140 quid for sum 8mm spacers, 12 longer bolts and a set of locking nuts. is that a good price or can i get them cheaper elswhere?
4: im yet to put my highsport coilovers on the car along with my front lower strut barce and i have to say the traction is crap on the standard set up. is there anything else i should get checked out before i add them mods or see what its like when the cloilies and strut brace are on
thanks guys n gall for any comments
cheers in advance
kenny
few things i need sum help with
Redline
- Sponsor
- Drives: BMW 128ti
I can help you with a couple.
For the black badge, use VAGParts (down the bottom on the main forum page).
To fit it to the front, basically you unclip the whole grille so you can get to the back of it. Then you have to get the existing silver badge out. I did this by literally cutting through the clips with side cutters. It's not really designed to come out, hence the vandalism! Then you just clip the new black one in.
As for your problems with traction, what tyres are you running? All well and good spending loads on suspension if you're not using decent rubber. Other thing I might suggest is that if you're fitting the lower strutbrace, get the upper one as well. I fitted the front upper to mine and that made a noticeable difference, planning on getting the lower one soon.
Good colour choice on the GTi as well
andrea
Hi
Try www.wheel-spacers.co.uk
This is where my other half got his wheel spacers from, i'm sure they are cheaper than Demon tweeks!
x
x
ModifiedMadness
- Sponsor
Mine neither. It was very very troublesome to try and get out! I was only really investigating how it can be removed when I last had the grille off, so that I know how when I get black badges, but nonetheless I couldn't prise it out of the grille!Redline wrote:ModifiedMadness wrote:The grille badge is easy to get out Redline you wimp(only joking)
For some reason mine didn't want to play the game!
ModifiedMadness
- Sponsor
