Whining/Wheezing?
Whining/Wheezing?
Hi everyone, another query about my gti:
when driving along, if i push the clutch in i hear a kindof quiet whining noise that reduces in pitch as the car slows down, but eventually seems to stop if i leave the clutch depressed.
Do anybody else's gti's do this? it's not that noticeable but if i listen i can hear it, just worried that it mite be something that shouldn't be happening!
Any help appreciated just so i can check if it's meant to do this?!
cheers ears
cheers ears
I had this problem ... it got worse very quickly and to cut a long story short cost me £1500 for new gearbox & clutch!!!
the release bearing went followed by a string of others within the box causing the casing to be damaged!
Hope this doesn't scare you off! but worth keepin an ear out for and if push comes to shove it's cheap enough to do the release bearing.
BTW if anyone wants a new gearbox for a GTI, I have it on good authority they are scarce to say the least. I had to wait 5 months for a replacement... non available anywhere on the globe according to VW HQ! that's quality for a 5 year old car innit!
So they should.
It depends which problem you speak of, they don't suffer from the pedal box issue, but the noise Ant43 was talkin about is normal. From what I can gather, the newer VW gearboxes are pretty pants (according to serveral VW mechanics) The mk5 polo ones are definately not the best out there.Ok. So does that mean the Lupo gearbox doesn't suffer from these problems then?
