how do you get the indicator lights to stay on, (usa style)
as the title says, ne help please!?
- Sponsor
running lights
you could run a few volts less than 12v from a regulator to the indicators which would make them illuminate dimmly, just use diodes so ur indicators dont turn into hazard lights lol
Re: how do you get the indicator lights to stay on, (usa sty
Sounds like your a puller for the copstupac2makaveli71 wrote:as the title says, ne help please!?
might look nice but not standard good luck
FIXEDfor those of u that are interested, here is a diagram of my prototype space battle cruiser
i dunno, maybe there's some kind of replacement flasher relay you could get that is normally closed instead of normally open like standard ones? the american style lights still flash when you move the stalk after all, its just that they blink out instead of turning on.
i think it's legal, i haven't seen any law against it, and i've certainly seen a couple american imports cruising about with such things. however it seems less a style statement, more a money saving gig for the manufacturers - they can do away with seperate front sidelights (using a yellow, rather than orange or white light) and the rear indicators (not even including an orange filter panel, just red)... the UK versions of some models supplied like this e.g. Volvos, have fully seperate (and therefore a couple quid pricier) sidelights that stay constantly lit rather than confusing people as to what the indicators are doing.
the police may still not like you for it and find reasons to pull you though. one troublesome thing with it is that typically when the flasher relay fuses out on a european car, the light will still come on (but not flash) when you activate the indicator... of course that won't work for the yank style, it'll either just break the circuit, or do nothing at all!
as regards the 350Z, i can't comment, but it was always intended as a thing to be marketed near exclusively to the american market, so it's not surprising. wouldnt be surprised if it's that way over here because of an oversight in the design dept, or theyve integrated it in a more sophisticated way than previously
re: diagram
aaah lol ive only just realised what you guys are after, the diagram above provide a small voltage to the lights which keeps the indicators half on when your side lights are on, it looks like your after indicators which are on normally and off when flashing, this is what your after ( the12volt style )
the main indicator supply wires are the wires from pins 3 and 7 from the indicator switch itself
