Polo mk1 vs. mk2 - chasis difference
TheFog
Post by TheFog »
I would like to know from reliagable sources are following parts of chasis 100% same on mk1 and mk2(mk3 perhaps):
->front moulds - probably the wrong term. I mean on that part of the under-hood chasis where shocks end
->floor (complete "downunder" from where are pedals (so to say) to rear bench. Central tunner perhaps? Side strips not necessery.
Thank you for your help in advance and my apologies for bad description. Greetings!
NornIron
Post by NornIron »
The front and rear floor pressings are definitely the same on Mk1 and Mk2 Polos, and I believe Mk3 also.
The front inner wings (wheel housings) are different pressings on Mk1 and Mk2 Polos, but I believe the same on Mk2 and Mk3.
Hope this helps :wink:
TheFog
Post by TheFog »
so I can replace my floors on mk1 with another from mk2? thanks a lot, this sure helps!
NornIron
Post by NornIron »
Shouldn't be a problem...part numbers are:
Floor plate (left) 867 803 997A
Floor plate (right) 867 803 997A
