How Do You De-Badge a 9N?
polomk6
Post by polomk6 »
hello,
i was wondering if any1 could tell me how to de-badge the back of my polo, which has POLO and TDI,
i've heard that you use a hairdryer ?
HELP!
thanks steve
mole
Admin
Post by mole »
Ok quickly as its been done before many times!
Using a hair dryer heat up the badge. I'd suggest doing it in a garage or on a warm day - not outside on a winters night!
Then slowly using some dental floss/cotton, behind the badge, work your way down "sawing" the adhesive. Then you'll be left with some adhesive on the bodywork. This will come off with a bit of work, and as long as you're careful, won't cause any damage at all.
Hope this helps mate.
Mole
Scorpio1
Post by Scorpio1 »
Noooo!!
Keep the TDI badge!
polomk6
Question
Post by polomk6 »
how do u get the adhesive on the bodywork off ?
mole
Admin
Post by mole »
I used WD40 - yes WD40! :roll: It get's everything off! And then finished it off with T-Cut. Perfect 8)
polomk6
De-Badged Successfully!
Post by polomk6 »
I de-badged it ok, used WD-40, came off ok , no problems,
thanks mole
mole
Admin
Post by mole »
Glad it worked ok! 8)
Mole
