i managed to get hold of a Multispline 8 Torq bit and tonight i started to split my BBS rims, first rim went ok (just) and i split it quite easily, came to the second rim and 2 of the BBS bolts slipped and i have rounded off the bolts (meaning they are still in the wheel
I have taken some pics of the first wheel and the second, i think the problem was the Torq Bit was bought second hand off ebay and it may (or may not) have been slightly worn (didn't look worn tho) and this is possibly what has caused them to slip ?!?! from what i have read i can get these drilled out and new BBS bolts can be sourced for about £1.75 each (ish) should i now purchase a NEW torq bit to do the other 2 rims or do you think i should carry on ? might get a new bit for when im re-building the wheels anyway ! aaaahhhhhhhhhh
Oh well, here goes
2nd Rim (2 bolts still in rim, top and right abit, bottom right abit again)
2nd Rim close up of Bolts
And now the 1st rim, split and ready for the tyre to be removed ready for the rim to get some serious wet n dry
Oh yeah, just to also add about the torq bit, it wasnt a completely snug fit in the bolts, there was a small amount of movement / play ????
Please can anyone help on what i should do next before a ruin the rest of my BBS bolts, is the torq bit correct having a slight amount of play when in the bolts ???
