Smoothing bumpers . .
- Sponsor
- Sponsor
- Sponsor
it is better if you can get it plastic welded as there is minimal filler/ fibreglass used but its a tricky 'art' so not everywhere can do it... if you get it fibreglassed then there is a risk it will sink but it can just be skimmed over at a later date (jus had mine done again and you wouldnt know!)
expect to pay around £250 to have it done and painted and a bit more if you have the front end blown in to colour match properly...
scott
scott
- Sponsor
Right this is what they do:
Mine cost £300 for front bumper, rear bumper, door handles and boot lock!
- Firstly they remove the bump strips
Then cut the recess out so it just leaves a hole
Then they weld a plastic sheet onto the bumper
Cut tiny grooves into the bumper across the area with grinder
Then they cover the area with fibre glass
Then they smooth it all off and put a tiny layer of bodge on
And then paint
Where did you get yours done from? Or did you do it yourself?PhilGTi wrote:Right this is what they do:
And then paint
