Bose Audio Upgrade
Vena_GTi
Bose Audio Upgrade
Post by Vena_GTi »
Has anyone considered or have already changed the standard speakers for Bose speakers? or have people gone specifically for more halfords style manufacturers...
Am i right to assume that the front and rear door speakers are 6.5" as i plan to change the standards for Bose aslong as the price isnt too excessive, although im not expecting them to be cheap
theclient
Post by theclient »
i replaced my fronts with alpine type s speakers and ther 16cm i think?
the fronts and rears (on the 3 doors) are all the same size.
:D
Mouse_GTI
Post by Mouse_GTI »
Would Bose speakers fit? I know Audi use a lot of Bose upgrades.
How good soundwise are the standard GTI speakers and CD changer unit?
theclient
Post by theclient »
the standard speakers and hu are pretty good.
i upgraded the unit because i wanted an ipod interface. i then managed to get a deal with the speakers, headunit and interface cheap, so had to be done.
i dont like alot of I.C.E - amps and subs, mainly because i need the room in the boot. i dont play hip hop/d'n'bass etc etc anyway just wanted a good sounding stereo 8)
Mouse_GTI
Post by Mouse_GTI »
Is the standard unit very bassy? Because that is the case with the Mk7 and with my dad's Mk5 Golf GTI. You'd think it had a sub!
benny oopz
Post by benny oopz »
My sound system is still totally standard. I thinks its a good system with good sound, and I'd say it is bassy.
It really impressed me whe I first bought the car, and as i'm no longer into amps & subs, have found no reason to upgrade.
But as theclient said an ipod interface, or hu that reads mp3 discs might be reasons to consider an upgrade.
inder
Post by inder »
Im going to be installing an geniune VW accessory to the standard headunit soon, it provides an ipod interface and can communicate with your Ipod thru the buttons on the headunit 8)
You lose the 6-cd changer in the boot, as it uses the same connection on back of headunit, but you can have the single slot one mounted in the dash, well I recon you can, will test.
Silky V
Post by Silky V »
The standard system is ok. However I have changed my headunit as the standard headunit doesn't provide enough power to the speakers.
Its funny how much of a difference it makes from just changing the headunit.
I'm running an Alpine CDA-7894RB, which is 60wx4.
Vena_GTi
Post by Vena_GTi »
Ive Called Audi, Nissan, Mazda and they all say that they either dont sell the speakers Aftermarket or they will not fit as they require special fitment
Si_GTi
Moderator
Post by Si_GTi »
I believe the majority of aftermarket speakers require an adapter of some sort or another to fit the OE speaker locations. Shouldn't be a problem sorting these out but I have no idea if Bose would be compatible. If they are, then that would be a nice little upgrade!
I'm just running the OEM standard setup in my GTi and I'm happy enough with it at the moment. I've thought about replacing the HU but can't find one I like so far and besides would like to keep the use of the 6-CD changer in the boot :)
Like theclient I need my boot for practical reasons so won't be having a sub or amp installed!
Vena_GTi
Post by Vena_GTi »
Yer, im running standard at the moment.. im not into all this 300watt speakers and amps and subs... the standard speakers are superb in my opinion but the passanger doo speaker has begun to rattle and after buying a bose radio player, the sound is awesome... so would really like it in my car if possible
Audi said that i will need slides to fit bose in (whatever they are) as they sell the speakers from the dealer...
ModifiedMadness
Sponsor
Post by ModifiedMadness »
Mouse_GTI wrote:Is the standard unit very bassy? Because that is the case with the Mk7 and with my dad's Mk5 Golf GTI. You'd think it had a sub!
It manages to shake the mirrors and the door cards a bit :lol:
PHILIP1193
Post by PHILIP1193 »
iv replaced my front componants with focal ones iv also got some 6x9's and it sounds mint ask si_gti h has heard it
Phil
JIC Cracked
Post by JIC Cracked »
ive changed my standard gti with bose out of a audi tt they sound great!!! :D but fitting them is not that straight forward.
Vena_GTi
Post by Vena_GTi »
PM Sent.....
Im looking forward to getting Bose in my car, hopefully you may be able to point me in the right direction...standard headunit?... did u have to change connectors etc ?
