www.peachorlemon.co.uk...
Nelson_Wilbury
Moderator
Post by Nelson_Wilbury »
Currently reading some interesting 'reviews' from 9n owners on www.peachorlemon.co.uk
Just to point out, a ':D' represents a peach and ':evil:' a lemon.
Allot of the reviews are bad, but to be fair you don't really go onto a sight like that to praise. Anyway...
* :D :D
Polo 1.4 Hatchback 2003
Wind noise coming from both doors at speeds over 40mph. Local dealer says VW UK have no record of this as a problem and so are dealing with Germany directly in order to develop a solution. Oddly enough the Polo demo car I drove before I bought the car had the same problem but I assumed it was a just a quirk on that particular car. I now wonder.
* :evil: :evil:
Polo 1.9 SDI Hatchback 2003
Problem with ill fitting doors and front windows which have constant wind noise around them. No effort made by dealer to deal with it - instead insists it's normal in the small Volkswagen cars!
* :D :D :D :D
Polo 1.9 TDi Sport Hatchback 2003
This is my 3rd new VW and it's another one that I’m very pleased with so far.
Diesel engine produces plenty of power and has no problems overtaking; in fact, it's surprisingly quick! Mpg is fantastic; I’ve been averaging 50 to the gallon on my 40-mile round-trip to work which is on both fast A roads and through a city centre.
This new Polo is such a massive improvement on the old one. I had a 1.6 16v Polo GTi before this and the extra interior space, both legroom wise and storage wise is much, much better. I particularly like the underseat drawers.
Only complaint would be that the dash rattles a wee bit, apparently something that is quite common, although it often disappears after a few thousand miles. [email protected]
(not rated)
Polo 1.2 SE Hatchback 2002
Looks like another dud one here. Picked the car up and discovered some poor paintwork so obviously been repaired. When it was done they didn't cover the rest of the car properly and there was lacquer overspray on the front of the car. VW dealer got it sorted and to a reasonable standard.
More serious problem was when my wife, a new driver, was out on her first night time run. Travelling around 55mph on an unlit road, put the lights on to full beam from dip, no lights!!!
Put the lights back to dip, still no lights! Luckily, she was on a straight bit of road and managed to stop safely. Scared her so much she won't drive again.
:D :D :D :D
Polo 1.2 Hatchback 2002
We have had our new Polo for less than a year and the crankshaft oilseal went after a couple of weeks.
Then the dashboard instrument cluster went defective, and then the alarm the dealer fitted went haywire. Now 10 months later, it’s all happened again.
We want a new car, where do we stand, any suggestions? [email protected]
:evil: :evil: :evil: :evil:
I’ve had the car since new in March 2002, it was running very nicely indeed for the first few months, it was too good to be true however.
The brakes suddenly became very noisy, a fine spray / pool of oil appeared on the plate at the front of the engine and the windscreen washer bottle was leaking.
The car was in the garage 6 times in total to have these things fixed, although in fairness the brakes were fixed on the first visit and the water bottle eventually replaced on visit number 3.
I was fobbed off by staff and told that there were no faults or leaks when it was quite clear there was and advised that the problems had been fixed when nothing had been done.
You could actually see water dripping out of the water bottle, however on the first visit I was advised that the bottle had been filled for me. Clearly unknown to them the only reason it has been empty was that the water had all leaked out.
The garage also managed to disconnect things and forget to reconnect them on occasion so there were a few unexpected things to contend with.
The crankshaft seal was replaced twice and still the oil leak continued. Eventually VW admitted that this was a known problem and that modified parts (crankshaft guide) were available. Subsequently the modified crankshaft guide was fitted and so far I’ve not had any oil appearing from this.
Yesterday I experienced another problem noted on this site. At first I thought I’d put the car into 3rd instead of 1st, however I discovered this wasn’t the case. Then I noticed the emissions light appear on the dashboard. It was either on or else flashing all the time.
My car is now back into VW who have advised that I need a new Coil Pack. I was advised that they would have my car for up to two weeks as they have no parts in stock and have had to order them.
I asked if this was perhaps a known problem as these parts seem in demand, the gentleman I spoke to hinted to the fact that this may well be the case. To their credit they have supplied me with a hire car in the meantime.
Looking at other messages on this site, it looks like VW will fix the problems if you have it however they will certainly not be contacting you.
If you’re close to the end of your warranty I’d recommend just having a look under the bonnet to see if there’s any oil at the bottom of the engine plate. It’s pretty obvious if there is and get them to fix it and keep an eye out on the dashboard too.
All this said I am still fond of the Polo, it’s a great small car to drive and would I get another though? We’ll see. I’ll probably wait until any new models have been around for at least a year before considering it.
Polo 1.2 (65hp) Hatchback 2003
Bought a new Polo for my daughter in Feb this year because my wife and I wanted her to be in a safe and reliable car. Before her 17th birthday, I decided to run her in for a few weeks (the car, I hope, PoL).
Over the four months that I have owned the car it has been in the shop seven times with the same persistent problem. After a long run the engine begins to run rough, stalls won't run in traffic without a third foot to keep the gas pedal down enough to prevent further stalls.
The problem seems to be down to an exhaust re-circulation valve defect. The first dealer in London (I happened to be down there for the day), replaced the ECU but that didn't fix the problem and on the way back from London, (yes I had to drive back down there to pick it up which is a 400 mile round trip), it packed up again.
The local dealer in Lancashire told me there was a pipe off and it would be all right now. Then attention started to focus on the Exhaust Recirculation Valve.
They replaced that, and it still broke!
Next was the communication between the ERV and the ECU, nope... that didn't fix it, then a new ERV, oh I missed the ECU being reset on one visit.
Then this weekend Volkswagen assist came out to it (one of the warning lights started to come on) and he said the ERV was U.S. (I think this stands for unserviceable) so its gone back in today for a new ERV. I asked the sales manager for my money back but he told me that this was not VW's policy. When I asked for a replacement car, he told me the chances were slim and that it was not his decision's but VW head office.
Having said all this, I think I might be better off sticking with a car that occasionally won't run (and does about 23 miles to the gallon) than some of the mega lemons that I have read on this web site.
Any advice on how to replace my piece of German junk with something with a little more Eastern promise? [email protected]
:evil: :evil:
Ignition plug blew after 8 month, fixed promptly by dealer but it cost me a half-day annual leave. Rear wiper blew, the water tube came off, it hadn't been pushed home fully on to the connector, and the water sprayed on to the motor and blew it.
There was a similar problem with the front wiper water supply, but no damage was caused. Again the tube was not pushed home fully on to the fitting. This is a very clear example of poor workmanship.
The third problem I have had is with oil leaking from the crank casing. I rang the Dealer and they admitted that Volkswagen knew about the problem was covered by the warranty.
The issue I here is that they were not going to tell anyone unless they experienced the problem, obviously hoping that the problem would not be found until the car was out of warranty, so check your crank casing before the warranty expires.
So far this car has lost me one day's annual leave. I switched to Volkswagen for it's legendary quality, unfortunately!
That’s all it is, a legend. I'll now have to find a car manufacturer who can deliver the kind of quality I had expected from Volkswagen.
Only had the new Polo a few months and now one of the warning lights on the dashboard lights up (catalyst). According to manual you should take it to Volkswagen service centre straight away to be checked. I did this but they say there is nothing wrong and that not to worry if it lights up! Sounds a bit weird to me as how am I supposed to know if there is a problem if the other warning lights come up? I wonder if anyone else has had a similar problem as it could represent a fault with the catalyst or the warning light procedure that needs to be rectified?
:D :D :D :D
Polo S 1.2 Hatchback 2002
I bought the car two months ago from new in Dec 2002. First of all it was not de-waxed properly and the radio did not fit. Dealer’s said we will de-wax it for you and they did de-wax and valeted it. Next thing was the a pillar trim that covers the wires on the driver's door out of it's socket and needed replacing before they had chance to replace it. The central locking button on the inside of driver's door stopped operating completely. It turned out to be the wire loom needed replacing when they replaced both parts after my car staying in the dealers for two weeks. This time they put small scratches all over the car and in few places paint is chipped. Also now the electric mirror switch is faulty and needs replacing. Dealers have no answer how the car got all this damages while it was in their possession and say they will fix everything but it seems everytime they fix something they are damaging something else.
Last edited by Nelson_Wilbury on Sat Dec 06, 2003 9:43 pm, edited 1 time in total.
KarlM
Post by KarlM »
So most of the problems seem to be occuring on the 1.2 models?
Nelson_Wilbury
Moderator
I noticed the Camshaft Oil leak is more common than I thought. What also didn't know is that there were modified parts availiable. I will be contacting my dealership about this tomorrow.
Allot of the negative comments seem to be with the dealers rather than the car. But it also seems they are placing there expectations FAR too high. Cars are hugely sofisticated (electronically and mechanically) compared to 10 years ago and you've got to expect at least a few niggling problems :roll:
dxg
Moderator
Post by dxg »
It might just be that most of the Polos sold are 1.2's. I certainly hardly ever see any with even the 14inch alloys (SE), let alone any of the Sports versions up in this part of the world... I don't believe I've ever seen a 1.9TDI in the flesh :(
Deek
(Still waiting for word from VW....)
dxg
Moderator
Post by dxg »
I can't seem to get that site to work (even when I delete the . off the end) - is that the right URL??
dxg
Moderator
Post by dxg »
HANG ON!!!!
Isn't the 3rd poster rather familiar?!?!
Nelson_Wilbury
Moderator
hahaha!! :lol:
leonsmith
peachorlemon
Post by leonsmith »
Yep, the 3rd poster is me :wink:
Hey, somebody has got to stand up for the 9n!
I also think all the negatives are coming from people who have bought a bog standard 1.2 which has probably cost them quite a lot compared to the other small cars around.
Nelson_Wilbury
Moderator
Re: peachorlemon
leonsmith wrote: Hey, somebody has got to stand up for the 9n!
Too right, someone has got to stand up for it :lol:
Personally, I too was expecting the 'you gets what you pays for' experience i.e. relatively trouble free experience and a better product.
I still believe I have the better product, but the experience has been somewhat dampened by the niggling faults.
Still love it though! :D
bertJ
Post by bertJ »
Nelson, just a little url typo. It's http://www.peachorlemon.co.uk not .com as in your posting.
Quite frightening all the Polo faults, I'm afraid that I'm going to add to the list.
Nelson_Wilbury
Moderator
Thanks Bertj, now edited :)
Many of the rear washer pipe problems are actually being caused by the owners themselves. They are using the rear washer when the jet is frozen and the pressure causes the pipe to come off. Not allot you can do about that as it happens on Audis/Seats/Skodas too :(
Clawz
Post by Clawz »
Maybe VW should add a little heated ring around each of the nozzles for the washer spray that autoheat like the wingmirrors? :P
Josh_PoloGTi
Drives: BMW E85 Z4 3.0i
Post by Josh_PoloGTi »
My front washer jets are heated, so it's not impossible!
Good idea there! Give the man a gold star!
Nelson_Wilbury
Moderator
A couple more new ones on there site...
:D :D :D :D
Polo Hatchback A/C AU 1.4 Hatchback 2002
Bought from new - one careful lady driver, full service history etc.
Generally very pleased with it but it occasionally cuts out for no apparent reason. So far, thank goodness only when stationary.
It starts again straight away. The dealership is trying to trace the fault but I'm not optimistic they'll find it.
Anyone out there had similar experiences/diagnoses? [email protected]
(not rated)
Polo 1.4 Colour Concept 2002
Lovely looking car inside and out.
However......Been in garage 4 times with same problems. Electric window decides every now and again to go back down when it reaches the top! Engine lights coming on! Mainly catalyst!!! Also a lot of movement in the gearstick when accelerating/decelerating in 4th gear, VW copped out!!! It’s normal.... apparently. WOULD LOVE A VW LUPO GTi though!!!
Overall - Want rid of it!! Not fast enough!! [email protected]
:D :D :D
Polo 1.9 SDI Hatchback 2002
Lovely car to drive and excellent fuel economy, my main gripe is that of ill fitting doors which have constant wind noise around them, especially the drivers that the dealer cures only to re occur a few days later. Anyone else have the same experience? Peter (in Cornwall). [email protected]
(not rated)
Polo 1.4 5 door Automatic Hatchback 2002
The EPC warning light on the dashboard comes on. The car, which is an auto, will start in park, but you cannot put the car into any gear. It feels like a physical problem but if you turn the engine off you can select a gear no problem.
RAC come out and seemed to know that a rear light is out, they put a new bulb in and the car goes.
This seems very odd, why would a failed bulb shut down the engine management system? Any one come across this problem as it suggests a design fault.
Who wants a car that will not go just because a bulb has blown? [email protected]
:evil: :evil: :evil: :evil: :evil:
Polo 1.4 Hatchback 2002
There is a widely recognised problem with many of these early Polo’s that VW are fully aware.
The Engine management and emissions lights on the dashboard keep reporting this problem, but VW do not know how to cure it.
Many people are now having these cars replaced.
Do not be fobbed off with excuses.
