coilovers
popeye
coilovers
Post by popeye »
after some info off those of you with coiles.
How big a job is it to adjust them on the car and also do they seze up after a while as i have read a few stories about them now.
for the price of them do you think its worth the hassel or do u think just getting a set of springs to do the trick?
Alex_6n2
Post by Alex_6n2 »
If you look after them well they shouldn't seize.
Depends on what make but most coilovers only need flat ground, a spanner and some time to adjust them
popeye
Post by popeye »
o rite so you reckon to stay away from the cheapies then!?
Any you can recommend? also with the standers 15" BBS wheels on how low can you go before you have to start worrying about sleeping policeman and stuff? :? [/img]
Dee-vub
Post by Dee-vub »
go for 80mm - 100mm on 15's, will look sexy as f**k. if you want to kee it relatively practical, i wouldnt go past 80mm.even there wil be a pretty harsh ride.
popeye
Post by popeye »
just been outside and measured 80 to see how tho it would make the car, and as far as i can see that would put the tyres up underneath the artches! :shock: surely turning becomes an issue! 50mm looked like the maximum really!
Randall
Post by Randall »
I would recommend you going for coilies produced from stainless steel - as non stainless steel ones will seize up quickly. Recommendations from speaking with others
FK Silverline range
KW
H&R
Rich
