Clicking noise when depressing clutch?
AKs_SlickPolo
Post by AKs_SlickPolo »
Ive noticed a clicking noise when depressing the clutch and when bring it back up. Ive had it for ages but never worried until someone told me it may be the clutch :shock:
Mines only done 30,000 miles now and the clutch is not worn at all, still drives and gearchanges are perfect with no crunching whatsoever. Ive got no operational problems at all. Just this noise. However I've only heard it when depressing the clutch with the engine switched off.
Does anyone else here this noise in there 9n or is it completely noise free?
xx_loopy_xx
Post by xx_loopy_xx »
Yeah mine makes a squeeking like noise when you press the clutch down and when you bring it back up. Scared me at first but just put it down to a "Volkswagen Noise"
AKs_SlickPolo
Its not a squeek really, more of a click, just wondering if its anything to worry about really? the noise dont bother me and its only heard when roads and car is switched off.
poloecosse
Post by poloecosse »
i have both of the noises, was a bit worried at first but it hasnt affected anything so i rekon it is normal, mine has only done 17k and it does it
like you said, i can only hear it with the engine off aswell
Gilly
Post by Gilly »
hi guys im just new on the forum.
have noticed the same clicking noise aswell. My polo has 34000miles on her. But again, the gear changing is still perfect.
AKs_SlickPolo
Welcome to the forum Gilly :D
Im going to a garage tommorow to sort a knocking noise from the rear. I will ask them about this and post up what they say about it 8)
Dezmoand
Post by Dezmoand »
Helo there..
Not sure if this helps, but I've had this problem twice now. Does the pedal feel a bit rough also? Like its a bit "rippley"... if you get what I mean? And does this only happen when the engine has warmed up?
If so, it should be the clutch release bearing. As I said, twice it has happened to me, both times, took it down to the dealer and it was a case of a warranty jobby. Although the second time (about 6 months later) got the engineer a bit miffed, so much so he replaced my master cylinder, or so they claim and took my gearbox apart, only discover that it was the same problem and so another clutch release bearing sorted that out.
The second time was in June of this year, so fingers crossed, cos my warranty runs out in about a years time..
Hope this helps!
:D
