How to test ABS on your desk
zakimaci
Post by zakimaci »
Hy ... I'm not from UK ... but I have few experiencies in car electronics.
I have a 6n2 1.4i 16V and 2 days ago I repaired my ABS ...
Look at the pictures how to test ABS at home ...
You need:
- AT power source
- OBD2 interface
- laptop or desktop
- a piece of 5 inch wire
- VWtools or Vag-com
Connect 12v+ on ABS module at pin 25 and 9
Connect 12v- on ABS module at pin 24 and 8
Connect K line to pin 7
And 12V+ on pin 4 to simulate that your car is started
zakimaci
x
Post by zakimaci »
Continuity between ecu - > abs -> dashboard
Can H ABS pin 11 -> Can H ECU pin 31 -> Can H Dash b20
Can L ABS pin 10 -> Can L ECU pin 32 -> Can L Dash b19
