GT Dizzy
edryn80
Drives: Polo Dune
GT Dizzy
Post by edryn80 »
Hello All,
I am new to this forum as I have just bought a nice little GT, its actually fairly beat up and broken but we shall rat it and all will be well.
Its not running, AA claim a dizzy fault, i assume its the hall sender. Does anyone have one for the multi point GT or know of any other cars that run the same so I can get one from a scrappies. (No GT's about...)
So please help if you can, pint at next years shows for giving me a hand.
Ted
DelG40
Post by DelG40 »
Can you get the number that's stamped on the body of the distrubutor and post it up here? Can determine if you have the right dizzy to start
GT/G40 specific dizzies end in part numbers "T" or "P" I think
Hall senders are also the same throughout the range - SPI and MPI engines. You can also apparently buy a replacement hall sender kit from VAG.
Other usable distributors include; Skoda 1.6 and Mk4 Polo both ending in part number 'AB' (which are both good alternatives if you are looking for just a suitable replacement)
Hope this helps
edryn80
Drives: Polo Dune
Post by edryn80 »
Hiya,
Sorry, been all over the place with work and stuffage.
Part number is (VAG) 030 905 205 P
Still after one!!!
DelG40
Post by DelG40 »
Replace the hall sender to start
As I previously said, these are the same throughout the range
See if that cures your problem
grantvw
Post by grantvw »
the hall senders arnt the same as a single point injection car i got one yesterday and the hall sender is at the top of the dizzy where as the hall sender on my gt is at the bottom which resulted in the car not firing when turning it over hall senders kits are £150 from vw and £250 for the complete dizzy i'm looking for a complete dizzy to if anyone knows where to get one cheap
creasegt
Post by creasegt »
if u can get me your full reg of the car, i can see if i can get hold of one for ya!
jonboy
Post by jonboy »
the actual sender is the same and you can rebuilt the gt dizzy using parts from an spi dizzy, personally i find it easier to find an mpi mk4 polo ibiza or skoda with the ab dizzy which is less suseptable to hall sender failure anyway. have them on both my g40 and gt and they run fine
dizzy rebuild link!
http://www.clubpolo.co.uk/forum/index.p ... opic=91373
pettsy
Moderator
Post by pettsy »
i may have one, but im trying to check if its a correct gt one. it has the bosch part numbers but no vw partnumbers.
sylvester
Post by sylvester »
Had one fitted by a stealer on a 1.3 single point, the dizzy was £90 about 4 years ago, ok I know it was a few years ago but I was surprised at the price then. It was an intermittant fault, but it had a knack of failing miles from home.
