Mini update
Phil6N
Mini update
Post by Phil6N »
Finally got round to doing my dials, heres d result
changed all the switch lights to red aswell.
Iv also done this trick thing when u open your door, LED's from underneath the door light up,and go off when u shut it. I'l get sum pic's up shortly of that.
Soz for the quality, phone to hand strikes again.
PeteJ
Post by PeteJ »
looks really spiffy phil.
what size leds/where from?
would be interested in a how to for this, specially if you've switched every single led rather than just a backlight.
mmh
Post by mmh »
Looking good Phil :D
Did you need to take the steering wheel off to get the dials out?
Also any problems with warning lights turning on after re-fitting the dials?
Is the dash brightness still dimmable?
Mo
Biddle
Post by Biddle »
Looks cool mate 8) I thought it was only valvers which had LED display lights? I was under the impression that all 8v/diesels were just a normal bulb with coloured plastic strips determining the colour?
PeteJ
Post by PeteJ »
98 onwards had the late style cluster. on all models so far as i know
Phil6N
Post by Phil6N »
My bro supplied the LED's from work, there surface mounted LED's, You change the majority of the LED's,not all.
Nope didnt need to take steering wheel off. No warning lights afterwards. I did have the airbag light on before i did the mod, so i just unsoldered that LED. They are still dimmerble.
Any polo after 98 has LED's rather than bulb.
Definate modification worth doing.
luke
Post by luke »
sorry to hi-jack your thread, but would i be able to drop in the newer clocks from a 98> in my 96 polo? or would the wiring be different? major modifications ? or not? its just that theres a few polo's up my local scrap yard.
cheers luke
Phil6N
Post by Phil6N »
to be honest i wouldnt know, i cant see why not though!
luke
Post by luke »
Phil6N wrote:to be honest i wouldnt know, i cant see why not though!
thats wat i was thinking, neways car looks nice. think the wheels suit make a change from the usual. clocks look funky too.
Luke
