Sorry to hear that Alun.
Sorry I don't have any suggestions as to what it can be. Having not had a gearbox fail yet, I don't know if that noise is similar. Hopefully, one of the unfortunate owners who has had a gearbox go on them, can chime in. I've only read the noise is of a "whine" - I havent heard the sound of a spitfire mentioned !
As you say it happens over 30mph, does it make the noise in all gears as well as neutral.
Bit of a problem. Possibly gearbox?
The little things do add up and get to you sometimes. Not sure if it's a wheel bearing. I just got one replaced but there was no sign it was out. Though on my old Fiesta, it used to squeal everytime I turned a certain direction. It was embarassing!
Best taking it down to a good garage to get it checked out, or your local dealer (if they are any good )
- Sponsor
I know the feeling Alun, i feel like getting rid of mine in the new year to be honest...
Ive been in a mates fiesta when his wheel bearing has messed up and it sounds like how you described in your first post. But when my gearbox went....the whole engine sounded rough, THEN i heard a whining noise (like a charger) then felt a clunk and stopped....It all happened pretty quick for me though, not over a space of a week or so.
Have you noticed this more when going downhill? and is it loudest around 30-40mph then goes away at higher speeds?
If you drive upto the speed or whatever that starts making the noise and clutch down, does the noise go away or is it still there? If it cuts out when clutch is engaged, its more than likely the gearbox, if not sounds like wheel bearing
Yep, That doesnt sound like gearbox, as the noise would also be more central/passenger side and high pitched whine too that cuts off when clutch is depressed.CymruPolo wrote:
@ AKs_SlickPolo: Not noticed more of a sound when going downhill, I've only done one journey in it since the noise started so it would be hard to tell. They noise is there all the time when going over 30mph even when the clutch is down/put in neutral.
So most probably wheel bearing then? And is there any danger in driving with it? (not that I will be this week - I'm getting a lift to and from work)
Sounds like wheel bearing. Like your noise, I seem to have one in my 9N (at the same side) but is quite quiet. It has supposidly started when i had my hub removed when the coilovers were fitted.
As you seem to have had a new hub, it might be related to that - perhaps something not properly fitted, but theres not much there except the wheel bearing.
Ive had mine tested by two garages and the MOT guy, and all say its fine. But i've heard some people still changing a bearing thats not gone and the noise disappears
A good way to check is to jack the car up, grasp the wheel at the top and bottom, and try rocking the wheel. Any play would indicate worn bearing. Spinning the wheel will also make you hear the noise too.
Although its not faulty, I'm looking to change my wheel bearing when money allows
Hope this helps
at first i thought the noise was comig from one of my wheels, then i thought it was coming from under the bonnet. Then when driving the car at the time, the noise was more noticable driving in gear, which lead me to think there was something wrong with the gearbox. I took it to a transmission garage who took it for a spin i diagnosed the bearing being the problem.
At the time i just wanted someone to nick my car!!
