[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Exhaust emission warning light??? - UK-POLOS.NET - THE VW Polo Forum
hi just noticed this light is now brightly lighted in my dials! just in time for xmas, now i have a cat back s/s sytem and been on for about 6 months is it to do with the emissions, do i ignore or do i just put it down to having this exhaust????
thanks
az_mk
p.s oh and hi by the way!
my advice would be take it to the garage where u got the exhaust fitted and tell them and see if they can do n e thing. if they say no then take it to a vw garage and see what they can do.
Mines done this when i put the decat on. You will need to get this checked as it may fail the mot with the emmisions being too high. In my case, i will just be sticking the cat back on and it'll be fine.
If its the EPC light then its complaining that its gone out of adaption range, which is probably to do with faffing about with the exhaust, and changing the backpressure or resonance.
If so, you will need to switch it to basic settings - which requires vagcom but will not bother you again.
vag-com is a fault code reader software that you put on your laptop and youand use it to read and and test componets just like a dealership but cheaper in the long run. hope this helps
ive had problems with my car befor like that. nothing happened tho. it was sorted easily and quickly........ my car should be perfect when i get it back tho from the garage. hopefully it'll be saturday so i'm looking forward to it.
