Page 1 of 3
Exhaust emission warning light???
Posted: Tue Dec 26, 2006 11:17 pm
by az_mk
hi just noticed this light is now brightly lighted in my dials! just in time for xmas, now i have a cat back s/s sytem and been on for about 6 months is it to do with the emissions, do i ignore or do i just put it down to having this exhaust????
thanks
az_mk
p.s oh and hi by the way!
Posted: Wed Dec 27, 2006 12:39 am
by kipper
my advice would be take it to the garage where u got the exhaust fitted and tell them and see if they can do n e thing. if they say no then take it to a vw garage and see what they can do.
Posted: Wed Dec 27, 2006 11:14 am
by Dee-vub
Mines done this when i put the decat on. You will need to get this checked as it may fail the mot with the emmisions being too high. In my case, i will just be sticking the cat back on and it'll be fine.
Posted: Mon Jan 01, 2007 4:24 pm
by JWC
Which light? The EPC?
If its the EPC light then its complaining that its gone out of adaption range, which is probably to do with faffing about with the exhaust, and changing the backpressure or resonance.
If so, you will need to switch it to basic settings - which requires vagcom but will not bother you again.
Posted: Thu Jan 04, 2007 2:57 pm
by collywobbles
My EPC has just come on aswell.
What's vagcom?
Posted: Thu Jan 04, 2007 9:36 pm
by polo power
vag-com is a fault code reader software that you put on your laptop and youand use it to read and and test componets just like a dealership but cheaper in the long run. hope this helps
Posted: Mon Jan 08, 2007 9:38 pm
by collywobbles
Okay the light has gone off, it has been like that a couple of days.
Is it going to blow up or what? lol
Posted: Tue Jan 09, 2007 7:06 pm
by polo power
probably just a sporadic fault then.
Posted: Tue Jan 09, 2007 10:23 pm
by collywobbles
It's come back on.
It's gunna diiiiiiiiiiiiiiiiiiiiiiie boooooohoooooooooooo
Posted: Wed Jan 10, 2007 8:49 pm
by polo power
best ad get it checked out then.
Posted: Wed Jan 10, 2007 8:51 pm
by collywobbles
Yeah am getting it sorted
Posted: Wed Jan 10, 2007 9:00 pm
by polo power
hope whatever it is wont cost to much
by kipper
ive had problems with my car befor like that. nothing happened tho. it was sorted easily and quickly........ my car should be perfect when i get it back tho from the garage. hopefully it'll be saturday so i'm looking forward to it.
Posted: Wed Jan 10, 2007 9:32 pm
by collywobbles
Thanks Guys
PP It's still under warranty so should be ok!
Posted: Thu Jan 11, 2007 12:50 pm
by collywobbles
It's booked in for Saturday, the guy even said i can have it back the same day
Wow!
