Vag-com
bombertdi
Vag-com
Post by bombertdi »
I have been reading about vag-com which allows the connection of PC to car to read settings and fault codes.
Does anyone know if this is compatable with the 9N ??
And where the socket located ??
jmv
Post by jmv »
yes i it is compatable, i think you use the diagnostic port under the steering column to connect it??
vwpolo16v
Post by vwpolo16v »
good topic bombertdi !
I have seen many different cables on sale on ebay -- all slightly different.
Question is which one works with 9N and where doe sone get the s/w from ?
I just got mine and love to find out what's going on under the bonnet :wink:
RichardBW
Post by RichardBW »
all the info you need here. The original (and no doubt the best) is cheap enough so dont waste your money on ebay.
http://www.ross-tech.com/
vwpolo16v
Post by vwpolo16v »
Thanks RichardBW. Looked at Ross-Tech. Did not see Polos listed to figure out which one of the 3 cable types would work with a 2003 9N Polo:
1. The KEY-Series (Compatible with older cars that don't use CAN).
2. The Micro-CAN (Supports latest cars which require a direct CAN connection for Cars based on Mk.5 technology only -- not sure what that means).
3. HEX+CAN Series that seems to support all car types
The confusing bit is they are selling for miminum of $229 (dollars) fo the cable whereas the eBAY ones are £17 (pounds sterling) -- big difference. Why ?
bombertdi
Post by bombertdi »
Thats what confused me ???
There are a few different interfaces but how do i find out which one fits 9N ??
Vag-com is apparently free to download off certain websites.
I suppose they are older versions not the latest.
[/img]
