Leak in the fuel pump housing
pitman
Post by pitman »
Hi!
The fuel pump housing is leaking from a small whole within the fuel pump cover. This whole is also shown in picture 4.6C "Showing the fuel pump sealing ring" in chapter 3.4 of the Haynes manual (#0813).
It's the whole on the left side of the arrow.
Surely, it looks that I have to replace the fuel pump after 22 years.
:shock:
I was only wondering if someone knows what the whole is for and why it is leaking, now. (I haven't opened the fuel pump, so far.)
steveo3002
Post by steveo3002 »
dunno the answer but mine leaks too? but just randomly..some times it s fine :?
pitman
Post by pitman »
Well, maybe mine leaks randomly, too.
I only saw that there was something leaking underneath the engine when I was shopping, leaving a spot of about the size of a palm. Keeping on shopping 8) , the spot varied much in size when I always came back to the car.
When I then examined the problem on the driveway, it took about 5 mins until it started leaking. :?
steveo3002
well for safetys sake just replace it, id like to know why they do it as mine was a recent gsf cheapie (replacing it with the dearer one )
mine only does it on start up , can go weeks without it then leak..it leaks about a cupfull then stops :?
just get a new one though mate...cheaper than a car fire or break down...gsf want £10 for a cheapie ot £25 for a good un, vag are about £45
pitman
Post by pitman »
Thanks for the prices! Didn't know that there is that much difference. :shock:
And anyone has an idea what the whole is good for apart from leaking? :lol:
steveo3002
i figure the hole is there incase it leaks...at least that way a minor leak will let it still work :?
hypojam
Post by hypojam »
Christ just replace it :shock:
I won my genuine VAG fuel pump of ebay for 7.50 delivered :o
omicron
Post by omicron »
Speaking as someone who's had a underbonnet fire in the last week. Replace it.
steveo3002
just got my £25 jobbie from gsf, its pierburg brand....the case is now made from black plastic :? hopefully its a improved version , i expect to get at least 18 years service from it :D
pitman
Post by pitman »
Can someone give me a hint how to remove these two bolts? The fuel pump cover lets me use only a standard L-shaped Allen key as shown in the Haynes manual. And the bots are simply too tight after 22 years.
Because of the pump cover I can't use the bits and sockets with the different ratchet drives I got.
I don't know if heating up the retaining bolts with a blow torch would be a good idea, maybe after trying to remove the pump cover. :shock:
Anyone an idea? :idea:
steveo3002
dont go heating a fuel pump mate..fires aint good
i used a hex key bit with a spanner on it....the type of bits that come in a screwdriver set, if you round them off hammer in a spline bit
pitman
Post by pitman »
steveo3002 wrote:dont go heating a fuel pump mate..fires aint good
That's what I thought in the first place. I thought better you ask if someone has done that before. :lol:
steveo3002 wrote: i used a hex key bit with a spanner on it....the type of bits that come in a screwdriver set, if you round them off hammer in a spline bit
Good idea! I got plenty of hex bits. I'll try it tomorrow evening. In the meantime, I hope WD-40 is doing something, too. 8)
steveo3002
mine werent that tight....needed a good crack with a decent spanner
one other thing..make sure the hex key is the proper size and not worn out, tap it in with a hammer if the bolts have grease n cr@p in em, because if you round them off its 10x more hassle
might be a idea to get new fuel hose too..some of mine was getting a bit spongy
pitman
Post by pitman »
With a hex bit and a size-10-spanner, cranked and longer than the normal ones, the screws went off immediately. :D
The fuel hoses are still OK. One I have replaced about two years ago. This Polo seems to like leaking fuel ... :roll:
DaMeat
Post by DaMeat »
P.S. They put holes in fuel pumps (and water pumps, etc.) so that when they wear out you can tell... I.E. They leak fuel, or water, and now it's time to replace them, as the seals have worn out!
