Someone once stated, on this very forum, "I've never seen a Polo GTI reach 80,000 miles on it's original gearbox". Well, my mileage currently reads 79856 as it sits on my drive and guess what? Gearbox woes
Currently, if I engage reverse it crunches. Every time. When I engage first gear it is very stiff and reluctant to engage, but once you coax the lever into position (notchy!) it is then OK. The change into second gear is easier but still a bit more difficult than it should be, then finally anything from third to fifth is fine.
There is no obvious whine apparent when driving. But, often when you engage first or reverse gears and sit at idle with the clutch fully depressed and the car in gear, a vibration is detected. I have only noticed this particular symptom in the last day or two.
My preferred mechanic (who is a very knowledgeable chap) suggests it is a sign that the synchros are slowly failing and sooner or later I will lose the use of the gears...
So its time to look out for a replacement 'box!
I'm off to Stafford this weekend for my Powerflow annual check up, so my mileage will rise above the accursed 80,000 mark before the swap, ha ha
Well it had to happen sooner or later didn't it!
